Windchill Workgroup Manager Customization
bbusschers
Version: Windchill 13.0
Use Case: I want to give the user the possibility to access directly sharepoint info pages to gain information and/or launch external applications etc.
Description:
Is there a possibility to customize the UI of the Workgroup Manager such as adding a TAB or RIBBON with ICONS as you can do in PTC Creo?
Other idea is to have the possibility to add more browser tabs with different (home) pages.
I have looked in the ini file but it seems that this is very limited.
Any idea or suggestion?
MCAD Mananger Benchmark
Hi @bbusschers
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
Thank you for your reply.
I will at it again and see if I can update and clarify my question.
bert
To explain it a little bit more:
The TOP ribbon contains the dropdown menus: FILE  VIEW GO etc.
Just below it there are the TABS: MAIN HOME etc.
Is it possible to customize these?
I have seen already that it is possible to add more tabs:
But I can not find a possibility to add icons or start commands to these additional TABS or toolbars.
Beside of the above I have seen that it is possible to open several Windows:
But when you arrange that you are loosing this when you close the application and start it again.
I hope this is clarifying I little bit where I am looking for.
regards,
Bert
HelesicPetr
(To:bbusschers)
Hi @bbusschers
I'm not sure if there is a simple configuration of the menu in WGM, I've never needed it..
You can check if a WGM Toolkit would be a way how to customize the WGM
Help Center - Windchill Workgroup Manager Client-side Customization
Help Center - Windchill Workgroup Manager Customization
Help Center - Registering a Custom Service
PetrH
