Hello everyone,
let's say I have the following PTC Project Structure:
A
|->SubfolderOfA
|-->SubSubfolderOfA
|-->AnotherSubSubfolderOfA
B
|->SubfolderOfB
Now "SubfolderOfA" has various Checkpoints, say v1.1, 1.2, 1.3, etc...
Now this is what I'd like to do, all of that <from the command line using si>:
> I'd like to checkout somewhere on my Filesystem (outside of any Sandbox) only "SubfolderOfA" (and all of it's child-Folders) and then switch between its various Checkpoints.
From what I could read in this forum, a build-sandbox could be a good starting point, like:
si createsandbox -P$MKS.pj --projectRevision=1.1
But, supposed the first step is right, how can i switch between the various Checkpoints of "SubfolderOfA"?
Thank you for your help!
Martino
I got the same error
then I checked with
si sandboxes
if this really is true.
This then brought me to the idea to try
si retargetsandbox --projectRevision=1.2 c:\absolute\path\to\project.pj
For me this seems to work.
BTW: You could also try %cd%\project.pj if your current directory is the sandbox.
Jürgen
Hello, a little update from my side.
I've executed the following commands:
si createsandbox --projectRevision=1.1 .
si retargetsandbox --projectRevision=1.2 .
But the latter gives me the following error:
Failed to retarget sandbox .: Retarget failed: The specified sandbox is not registered as a top level sandbox
Same error with an additional argument:
si retargetsandbox --projectRevision=1.2 project.pj
Using the GUI I'm able to retarget the sandbox successfully: 'Sandbox'->'Retarget'
So what am I doing wrong with the call to retargetsandbox?
Thank you
Martino
then I checked with
si sandboxes
Jürgen
This brought me to the idea how to generate a more compact view of
project differences (members only, no subprojects)
si retargetsandbox --projectRevision=1.6 %cd%\project.pj
si print --recurse > sb_1_6.txt
si retargetsandbox %cd%\project.pj
si print --recurse > sb_CURRENT.txt
si difffiles --gui sb_1_6.txt sb_CURRENT.txt
Hello Klaus,
sorry for the late response, I was on vacation
Your solution with the absolute Path solved the Problem!
Thank you a lot!
Martino
