Hello All,
I have been observing this issue in 13.2 version and not for the other versions.
The size of the display changes when we connect to multiple screen. Ex: in the attachment (UI size) you can see that the size is very small.
in the other attachment you can see that the screen is unresponsive and where you point and click is not the same as what you see.
When switching from multiple screen to single screen the user interface is not manageable.
