How to find out out the original Archive information for Shared Member
pnone
Hello Support,
When I share a member from one sub-project to another sub-project, the icon at both the sub-project's shared member becomes SHARED HAND symbol similar to Add Shared SubProject.
Now for Shared Sub-Project if I see the "view information" menu, I can understand the original Sub-Project location from the shared location.
For the Shared Member, "view information" menu output doesn't show the original location from where it was shared. It shows the corresponding project location for both the places [Shared and Source location].
Question is how do I find out where is the source location and where is the shared location for a Shared Member?
Any clue will help me a lot.
Thank you.
awalsh
17-Peridot
(To:pnone)
You can see this from the Archive Information dialog.  With the member highlighted, select Member > Archive > View Information (you may need to add this to your menu).
The Archive Name is the source location for the member.
awalsh
17-Peridot
(To:pnone)
ssaul
(To:pnone)
In addition: If you want to see all archive locations in the list view, you can also add a "Member Archive" or "Working Archive" column (right-click on any column header, "configure columns", add member or working archive from not visible to visible).
