Hello everyone,
I am looking for a way to prevent the mass modification of mks domain groups. In the last month, I have had to restore the membership table multiple times because all the users were removed from an access group. We are setting up a job to duplicate the table locally so at least the restore will not take as long, but this still requires a bounce and that is difficult to schedule.
Any suggestions are appreciated.
Thank you,
Paul Hartwig
Hi Paul,
how can a system decide if the mass operation is acceptable or inacceptable?
Volker
(I assume that you have provided access to this functionality to approved administrators only, right?)
