What is the maximum file size i can upload in Integrity 10.7.
Hi Indraneel,
By chance, did you open a Support case for this same question?
Are you talking about file attachments on Workflow & Documents Integrity items? Or are you talking about Configuration Management, and file size for "check-ins"?
If you're talking about the former, you can control file size attachment to Workflow & Documents items, with the following propery:
mksis.im.maxAttachmentSize
The maximum is 256M.
Hi Indraneel,
Hello Indraneel Saha,
If you still need assistance with this, can you please let us know the challenge(s) you are still facing?
It looks like Michael's solution is correct, would you please take the next step and mark this answer as "Correct Answer"?
This way other users reading the thread will know there is a solution, and which answer is correct. In addition, it makes the solution easier to find.
Thank you,
Adam
