Hi All,
I am able to create a EPMDocument with API at first time.
i want to iterate this EPMdocument for updating its contents, how i can do this, because my code gives me "Error in Document Createwt.vc.VersionControlException: wt.util.WTException: wt.pom.UniquenessException: CAD Part" exception.
Please help me to Build the EPMdocument A.1 and A.2 with modified contents.
any help will be great.
Vivek
Hi.
You can create EPMDocument A1 and add the content. Then check out it, modify content and check in it.
Hi Anton,
Thanks for your response.
Now i am able to check out the EPMDocument with API, and check in back to Windchill without modifying the content.
as simple part A.1 to Part A.2.
but when i am trying to update its content, it gives me below error, please suggest how i can modify the content file also while check in i to Windchill.
Uploading file to Primary
java.lang.reflect.InvocationTargetException
at wt.method.RemoteMethodServer.invoke(RemoteMethodServer.java:800)
at wt.clients.util.RMIMultiPartPost.performOperation(RMIMultiPartPost.java:257)
at wt.clients.util.http.HTTPUploadDownload.performUploadOperation(HTTPUploadDownload.java:1357)
at wt.clients.util.http.HTTPUploadDownload.access$100(HTTPUploadDownload.java:54)
at wt.clients.util.http.HTTPUploadDownload$HTTPUploadDownloadThread.run(HTTPUploadDownload.java:2728)
Finished uploadFile of [wt.epm.EPMDocument:194491]Caused by: (wt.content.contentResource/66) wt.content.ContentException: Can not add more than one primary content to the object.
i am using below code for check out EPMDoc.
//check out
wt.vc.wip.WorkInProgressHelper.service.checkout(doc, wt.vc.wip.WorkInProgressHelper.service.getCheckoutFolder(),"Iterated by Administrator");
System.out.println("Checked Out ...done.");
//for Check In
if(wt.vc.wip.WorkInProgressHelper.isCheckedOut(epm)) {
epm = (wt.epm.EPMDocument) wt.vc.wip.WorkInProgressHelper.service.checkin(epm,"checked in by xxx");
Please let me know how i can modify the content of EPMDoc and check in back to Windchill.
Any sample code will be great help.
Vivek
Hi Vivek. I have never updated primary contents by code, but I am using below code for seting the secondary content:
public static void addDescribeFileToDoc(WTDocument wtd, File file) throws Exception
System.out.println("Add secondary");
byte[] byteArray = FileUtils.readFileToByteArray(file);
ContentHolderHelper.setContents(wtd, byteArray, ContentRoleType.SECONDARY, file.getName(), "", false);
You may try to change this method like this:
public static void updatePrimaryFileToDoc(WTDocument wtd, File file) throws Exception
ContentHolderHelper.updateContents(wtd, byteArray, ContentRoleType.PRIMARY);
