Can you host a Creo Parametric 4.0 installation on a virtual server and have it connect to a Windchill installation hosted on a separate virtual server?
kkillian
Hi all, I have a bit of a quandary.
For a brief moment, I was able to host an installation of Creo Parametric on a virtual server, open Creo on my workstation, and connect it to another separate server that was hosting Windchill. Now when I launch Creo Parametric and click on the server manager, Creo throws an error: "The server is not supported." Does anyone have any experience with an issue like this?
TomU
(To:kkillian)
At this point I would probably try two things.
  1. Open a case with tech support and see if they have any ideas.
  2. Install Wireshark or Fiddler and see it you can identify the call that is failing.
12 REPLIES 12
TomU
(To:kkillian)
Assuming the versions of Creo and Windchill are compatible, I would suggest removing your local cache and then using the environment variable PTC_WF_ROOT to control where this cache is being created.
kkillian
(To:TomU)
I am running the latest versions of both Windchill and Creo Parametric.
Okay, so this cleared all of the servers in the server manager.
After running a script setting this variable to a temp folder on my C:\ drive, I attempted to register my Windchill server with the server manager. This resulted in an invalid server location error. I know the server exists, and I have had an admin open all of the ports (so this shouldn't be a port problem), so do you know what the stumbling block is?
TomU
(To:kkillian)
Can you access the server from a standalone browser?  The url is exactly the same for Creo (up through the Windchill part).  Keep in mind that it's case sensitive (capital 'W'.)
http://<server name>/Windchill
kkillian
(To:TomU)
I am actually logged in right now. That is the thing that baffles me about the server problem. I am literally copying the URL up to and including the "Windchill."
TomU
(To:kkillian)
Have you tried restarting the Creo VM?  Sometimes a Creo process will hang and not work correctly until you either kill it or reboot.  (Not talking about xtop.exe)
SergeyEfimov
(To:TomU)
Can you ping the Windchill server from your Creo workstation?
I pinged the Windchill server URL and got nothing back. However, when I pinged the server that was hosting Windchill, I got a response. Does that mean I might have some DNS issues?
SergeyEfimov
(To:kkillian)
It may be a problem with network connection settings of your virtual machines.
TomU
(To:SergeyEfimov)
If he can access Windchill from a stand alone web browser on the same virtual machine Creo is installed on, then the network settings should be okay.
kkillian
(To:TomU)
After remoting into the server and connecting via web browser, I have found that there is no issue connecting to Windchill from the vm server that Creo is installed on.
TomU
(To:kkillian)
kkillian
(To:TomU)
Yeah, I think I will escalate this.
Thanks for giving me some help, all!
