Check for Checked Out objects in the Affected Data section on a Change Request
lgrant
I'm looking for some transition "complete" text that will check that all objects (primary business) are not Checked Out (or are Checked In).
I see some examples for Promotion Request but this is on a CR.
My problem is that we have users add "In Work" state objects to the CR, the workflow starts at a Submit CR task then we have them add approves at Assign CRB task. At both tasks, the authors could edit the objects in the Affected Data section but, if they are left Check Out then the workflow cannot change the state of the objects as the task moves to Doc Control to check the Change Request.
I already have a conditional that will Cancel the CR if any object in the Affected Data is not "In Work" as we do not want the users to set Released documents to Under Review.
satre-2
(To:lgrant)
See attached document for implementing business rule for change request to check if affected objects is checked out.
Hope it helps !!!
Shreyas
7 REPLIES 7
In the workflow you can use business rules engine to check the condition whether the PBOs are checked out - CHECKOUT_RULE
Read more about it here - http://www.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=WCCG_BusLogicCust_ChangeMgmt_BusRules&action=show
Binesh
Barry Wehmiller
satre-2
(To:lgrant)
Since you already have condition to check if objects are not in in work state. you can add below line to check if object is checked out or not
boolean isCheckedOut=WorkInProgressHelper.isCheckedOut((Workable) object);
Hope it helps!!!
Shreyas
lgrant
(To:satre-2)
Thanks - I don't know xml. Is there a "sample" that has the xml for a conditional to check for Check Out objects?
satre-2
(To:lgrant)
For sample xml files for Business Rule you can check zip files under \Windchill\loadFiles\ixbImport\ folder
ChangePreReleaseBusinessRulesObjects.zip contain business rule for Change.
Hope it helps !!!
Shreyas
lgrant
(To:satre-2)
This?
satre-2
(To:lgrant)
Hope it helps !!!
Shreyas
lgrant
(To:satre-2)
Thanks Shreyas, that worked great. I just needed to add a Loop into the leg from Resolve to the Conditional.
