I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.14
Import is not working as expected, getting unwanted errors.
Here are the errors that I faced
Import started...
Started object creation process...
com.ptc.windchill.option.model.Option:1445524|178845396-1568923833896-1164344728-23-128-64-10|ABB-IAEN-qa.ptcmscloud.com,"Design Option - 00082, Channels" is successfully imported.,com.ptc.windchill.option.model.Option:121158921,Design Option - xxxx, Chaxxxx
com.ptc.windchill.option.model.Option:1445617|178845396-xxxx-11643447xxxx28-23-128-64-10|xx-xx-qa.xx.com,"Design Option - 00083, Red.24V Supply" is successfully imported.,com.ptc.windchill.option.model.Option:121158922,Design Option - 00083, Red.24V Supply
com.ptc.windchill.option.model.Option:1679369|xxxx-xxx-1164344728-23-128-64-10|ABB-xx-xx.xxxx.com,"Design Option - xx, SKELETON" is successfully imported.,com.ptc.windchill.option.model.Option:121158923,Design Option - 00087, SKELETON
com.ptc.windchill.option.model.Option:1445732|178845396-1568923833896-1164344728-23-128-64-10|xx-xx-qa.xxx.com,"Design Option - 00086, Extended IO" is successfully imported.,com.ptc.windchill.option.model.Option:121158924,Design Option - 00086, Extended IO
com.ptc.windchill.option.model.Option:1595016|178845396-1568923833896-1164344728-23-128-64-10|xx-xx-qa.xxx.com,"Design Option - 00085, Converter" is successfully imported.,com.ptc.windchill.option.model.Option:121158925,Design Option - 00085, Converter
com.ptc.windchill.option.model.Option:1584046|178845396-1568923833896-1164344728-23-128-64-10|xx-IAEN-xx.xx.com,"Design Option - 00088, OPTIONS" is successfully imported.,com.ptc.windchill.option.model.Option:121158926,Design Option - 00088, OPTIONS
Object com.ptc.windchill.option.model.ChoiceMaster:7252466, A exists with the UFID that is different than the UFID from XML
THE RESULT OF THE IMPORT :FAILED
Hi @RK_10391651
Have you try to export and import options and variants from one windchill instance to another?
if so you need to identify the com.ptc.windchill.option.model.ChoiceMaster with UFID and check what is in your system. There can be another one with different ID and you need to change the source file.
PetrH
<masterUfid> Is unique i know and there are N numbers of files under Exported Jar files, Including Several other objects each file we need to made the changes?? or there is any master file where we can reflect and update this info??
Hi , the seen message can be skipped by keeping existing objects ,see https://support.ptc.com/help/wnc/r12.1.1.0/en/index.html#page/Windchill_Help_Center/ExpImpPolicyRules_Chp/ExpImpPolicyRulesChp_ConflictMessagesPackages.html
Hello @Fadel ,
Thank you for your response, But somehow i am missing how to apply the solution, if this is overridable conflicts - YES.
Also if we want to use some RULE for import , Do you have example template if yes please share ...
This is how override the conflicts
Hello RK_10391651,
You encountered unexpected behavior while using Windchill, thanks for reaching out, this is Charles from PTC Technical Support in Europe.
Was the information provided helpful somehow?
KR,
Charles.
