Can somebody let me know how to publish custom objects which are not extended from WTPart.
I want to publish some modeled objects, some objects extended from WTDocument .
Also I want to publish item note attached to WTPart object.
Can somebody please provide me the detail steps to do it?
What classes I need to create?
Thanks in advance,
Swapnil
