I try to rename or open some assemblies on Windchill and gives me a fatal error message.
What could be the reason??
Thanks for the attention.
Best reguards.
Luca
Is the error message coming from Windchill or from the CAD client? What is the text of the error message? Is there a corresponding error message written to the Method Server log?
Hello Chris,
I understand what is the cause of the problem so I solved.
Essentially I was wrong to charge the family table with their instances
consequently it made me crash the program.
Hi Chris,
Can you advice how to fix this issue bellow.
The massage shown as ,
"Fetal Error Encountered.A trace back has been written to E:/PTC/creoUser ----traceback.log"
Please advice.
Best Regards,
Duminda
Hi Duminda,
1. Close Proe-E
2. Rename .wf folder from C:\Users\1034865\AppData\Roaming\PTC\ProENGINEER\Wildfire\.wf, with other name.
For Windows7 PC : C:\Users\1034865\AppData\Roaming\PTC\ProENGINEER\Wildfire\.wf
For Windows XP PC C:\Documents and Settings\Administrator\Application Data\PTC\ProENGINEER\Wildfire\.wf
3. Start the Pro-E
4. Afterwards you can delete renamed .wf folder.
.wf folder :- user workspace cache location
Try this.....
Sujata Chavan
