Hi..
Here we are facing one problem related to workflow. We are not able to open workflow in correct format. Very large view occurs when I open the workflow. Please find attached file for your reference.
Sujata
Sujata,
Do you have a valid support account, and can you view this article? CS139386.
If the steps in the article don't resolve it, are you using 32-bit browser on the 64-bit machine? Perhaps try using only 32-bit java install. And as always, make sure you're using the proper java version that is supported for your version of Windchill. Refer to the software matricies.
Sujata,
Hi Ben Perry,
Thank you for your reply. Now its working fine..
Sujata Chavan
