I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020 CPS30
No of Cached files are not changed even after did a manual sync thru JConsole.
Hi @spitchan
The cached files could be not referenced file anymore so the synchronization is not needed.
PetrH
What does it mean by referenced files?..you mean referenced in any other Assembly ? We tried running the
Go to JConsole > wt.method.Method Server Main* MBeans > com.ptc > Monitors > Cache Vault Synch > Operation > SysForceSync.
But still the cached files are not reduced.
