OIR CREATE, MODIFY ERROR
YJ_10068754
hello. I want to modify EPMDocument OIR. However, an error occurs when creating or editing something.
INFO: wt.system.err wcadmin - MPInputStream object body top boundary mismatch
INFO: wt.system.err wcadmin - expecting ------WebKitFormBoundaryE1m4lu5jFp1z5kHW
INFO: wt.system.err wcadmin - found
ERROR: com.ptc.jca.mvc.controllers.ActionController wcadmin - java.lang.reflect.InvocationTargetException java.lang.reflect.InvocationTargetException
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
---- Omitted below ----
Is there a solution??
Hi @YJ_10068754
Yes, you need to correct your modified XML.
I guess that something is wrong in your XML file.
Try to export the OOTB OIR and load it back.
If it does not fail, your modification is bad formatted.
PS> share your OIR xml definition
PetrrH
YJ_10068754
(To:HelesicPetr)
After checking many things, it doesn't seem to be a problem with the OIR file. The error also occurs when exporting and reinserting the current OIR. Also, an error occurs when exporting and inserting the basic OOTB OIR file. Is there somewhere that manages permissions for creating and editing OIRs? While looking for technical documentation, I heard that it might be an ACL-related issue. The contents of the OIR are attached below.
<AttributeValues objType="wt.epm.EPMDocument">
<!-- set the folder -->
<AttrValue id="folder.id" algorithm="com.ptc.core.foundation.folder.server.impl.FolderPathAttributeAlgorithm">
<Arg>/Default</Arg>
</AttrValue>
<!-- set the lifecycle -->
<AttrValue id="lifeCycle.id" algorithm="com.ptc.core.foundation.lifecycle.server.impl.LifeCycleTemplateAttributeAlgorithm"
ignore="false"
force="false"
final="false">
<Arg>Basic</Arg>
</AttrValue>
<!-- set the team template -->
<AttrValue id="teamTemplate.id" algorithm="com.ptc.core.foundation.team.server.impl.TeamTemplateAttributeAlgorithm">
<Arg>Default</Arg>
</AttrValue>
<!-- set the number to a generated number -->
<AttrValue id="number"
algorithm="com.ptc.windchill.enterprise.revisionControlled.server.impl.NumberGenerator"
ignore="false"
force="false"
final="false">
<Arg>{GEN:wt.enterprise.SequenceGenerator:EPM_seq:10:0}</Arg>
</AttrValue>
<!-- set the version info to a generated version info -->
<AttrValue id="MBA|versionInfo" algorithm="com.ptc.core.foundation.vc.server.impl.VersionInfoGenerator">
<Arg>wt.series.HarvardSeries</Arg>
</AttrValue>
<!-- specify AttrConstraint tag -->
<AttrConstraint id="lifeCycle.id" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
<Value algorithm="com.ptc.core.rule.server.impl.GetServerAssignedConstraint"/>
<Value algorithm="com.ptc.core.rule.server.impl.GetImmutableConstraint"/>
</AttrConstraint>
<AttrConstraint id="lifeCycle" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
</AttrConstraint>
<AttrConstraint id="folder.id" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
<Value algorithm="com.ptc.core.rule.server.impl.GetServerPreGeneratedValue"/>
</AttrConstraint>
<AttrConstraint id="number" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
</AttrConstraint>
<AttrConstraint id="teamTemplate.id" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
</AttrConstraint>
<AttrConstraint id="teamTemplate" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
</AttrConstraint>
<AttrConstraint id="organization.id" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
<Value algorithm="com.ptc.core.rule.server.impl.GetServerPreGeneratedValue">
<Value algorithm="com.ptc.windchill.enterprise.org.server.impl.OwningOrgDefaultAlgorithm"/>
</Value>
</AttrConstraint>
</AttributeValues>
thank you. @HelesicPetr
Hi @YJ_10068754
If it is ACL issue, so put your account to the administrator role.
It the issue is solved, yes it is ACL issue.
PetrH
YJ_10068754
(To:HelesicPetr)
The wcadmin account performing the task is already a member of the Administrators group. Is there a way to grant ACL administrator permissions other than this method?
Hi @YJ_10068754
If the user is a member of administrator group, it seams that the issue is not ACL configuration
but you can try
Setting Permissions through the Policy Administration Utility
PetrH
YJ_10068754
(To:HelesicPetr)
In policy management, the administrators group has full wtobject privileges relative to root privileges. I have no idea what the problem is.
