File vault by location or countries
rbhoraskar
1. Let’s assume Master Windchill is located in “UK”
2. We want to use same Master Windchill in “Canada” and “Netherlands” as well.
But we have an Export control and security control policies which says that:
Ø The Data or files created in Canada, they should be vaulted to Canada and does not go to Master in Uk
Ø Same for Netherlands Data or files created in Netherland, they should be vaulted to Netherland and does not go to Master in UK
Is this scenario is possible to achieve when UK is master server and Canada and Netherland is “File Server”.
If yes, how can we achieve this ?? for example
· Vaulting rules ?
· File Vault configuration ?
· No Replication/Sync to Master in UK??
Looking forward for your suggestions.
bmüller
(To:rbhoraskar)
are products in Canada and UK different or do engineers work on the same products together?
In general, a multi vault setup is possible, yes. Do you have some VAR to support you?
br Bernhard
Hi Bernhard,
Yes they are different Product and Library so no interaction between countries for Data.
There is possibility of having different ORG level itself for Canada and Netherlands for example.
Rahul
