Getting useful Change Notice info from Windchill
pnelson
3-Visitor
I'd like to compare and track efficiency at the different stages in a Change Notice.  How can I get basic information such as the Date Started and Date Completed for the "Tasks for Change Process" in a Change Notices?   The OOTB reports do not seem to include this. Can the OOTB reports be modified to add this? Do I have to go to the full blown Cognos license to get anything really useful?  Thanks!
MikeLockwood
22-Sapphire I
(To:pnelson)
Query builder reports can return:
- Time between Change Object states (Object History)
- Time between Tasks associated with Change Objects being delivered (created) and finished (there are Actual Start and Actual Finish fields on Work Items as well)
One can run these for a calendar time period, then get distributions by Role, Product, etc.
It gets a bit complex and possibly misleading if your workflows loop back, and if more than one user needs to Vote to complete an Activity.  But - Fairly understandable and useful results in general.
Reporting on change is infinitely easier if the Task names include a prefix / suffix indicating what object their workflow is tied to (e.g. CNxxx) for the task name on a change notice workflow.
AL_ANDERSON
(To:pnelson)
I created a presentation, 20150924 Query Builder Tips and Tricks, that I shared with the Windchill Technical Committee that shows how to make 3 different kinds of change status reports.  One of them includes how to show a pie chart of tasks On Time, or Not On Time based on ECT Need Date.
I"ve attached a copy here as a PDF for your reference.
I also posted the source code for a customization to mass update need dates so you can keep all of your ECTs in line with changes to your MS Project Plan on this same forum.
Al Anderson
I uploaded this query a few weeks ago.
Change Notice Report.qml
(I uploaded one for Change Activities as well.)
It doesn't have the exact information you're requesting, but it should be a useful base coupled with Al's presentation. Tech Support helped build this so you could always open a ticket with them. It took a bit of time but was very useful in both getting it running and helping me learn some about how to build reports.
LoriSood
(To:pnelson)
Hi Pete, was the Query Builder information provided helpful in getting you an answer to your question?
