I need to write script which will gather information on how tables are connected .
For example, Consider WTPART table i want get list of tables it is connected with and how it is connected.
Thank you in Advance.
That will be difficult. The Windchill database doesn't use foreign key constraints, so there's no easy way to get a list of which table references which other tables.
Though, you may be able to use the classnamekey columns to get this information. For each foreign key column in a table, there is a corresponding classnamekey column that holds the name of the table that the foreign key references. For example, the ida3masterreference column of WTPart is a foreign key to the WTPartMaster table. There is a corresponding column in WTPart named classnamekeymasterreference which contains the text 'wt.part.WTPartMaster'. As another example, the ida3containerreference column of WTPart contains a foreign key to the container context of the part (which could be a product, project, library, etc). The corresponding classnamekeycontainerreferen column will contain text like 'wt.pdmlink.PDMLinkProduct', 'wt.projmgmt.admin.Project2', or 'wt.inf.library.WTLibrary', depending on the type of container.
What you could do is get a list of all the columns beginning with classnamekey for each table. Then, for each of these columns, get a list of the distinct values in that column. From that, you can figure out how the tables are connected.
The Windchill database doesn't use foreign key constraints...
Why not? Isn't that kind of the point of a relational database? What benefit does not using foreign keys bring?
Trying to answer my own question...
There are some interesting opinions about foreign keys on this page: database - What's wrong with foreign keys? - Stack Overflow
I like this one: "foreign keys are like brushing your teeth: go ahead, do without it, but careful when you smile"
