Is there any action or configuration to generate routing sheet in MPMLink if Windchill System is not integrated with SAP?
Thanks & Regards
Kshitiz
which version of Windchill MPMLink you are using ?
routing sheet in Windchill means Work instruction and they are dynamic in nature.
In order to get Work instructions you need to create Process plan with Operations and sequences with part and resource allocations.
