We use the comments field on New Change Tasks to write lengthy descriptions on each object that will be changed on the ECN.
Out of the box, this field is quite small and only displays a partial view of the text that is entered. This makes it hard to proofread comments and view formatting.
Is there anyway to make this text box bigger so that more of the text is visible?
We are on Windchill 11.0 M20.
Thanks in advance for any suggestions.
@zgodula
Don't know if you ever got helped, but Wrap Text is available and probably will solve your issue. Select the pull down arrow on any column and select Wrap Text.
James
@STEVEG
Ugh, I don't know, but I tend to complete my comment in a notepad window, cut and paste it into that ridiculously small box. I wish it could be expanded as each user wanted.
Jams
@zgodula There is a "Was this information helpful" dialog. I selected no and said it doesn't work. Maybe you can do the same?
Good call, done.
I suspect this may be related to this known issue:
https://www.ptc.com/en/support/article?n=CS214887
Seems like a clunky work-around to me, but maybe try it, and see if that helps at all?
Nope. That doesn't work.
