Where is your CreoView Adapter (Publishing software) installed? Is it on your Windchill server or another computer in your network?
The steps to install a new version don't differ much.
What version of CreoView Adapter do you currently have installed? You may need to install a newer version of that, too.
The Creo software must be installed on the same computer that has the publishing software.
Install the Creo version that you want to use for your publishing.
Be sure to set your config.pro settings for your local install of Creo for publishing. There are some settings that should be turned off when publishing files.
Run the CreoView Adapter configuration program and set it to use the new Creo install location.
I've kept the same CAD worker server for many years now. At some point I will upgrade OS but it serves all my environments. I have separate Daemons (worker services), ports and publishing folders. It was easy to install new versions of Creo, create separate worker folders and you can tied them to specific start commmands from Creo (version specific). In this way, you can upgrade the software versions in parallel with production being in operation. My steps would be to install the new version of Creo you want to use with Windchill 13, highest it can support. Install Creo Adapters to the highest version supported. Configure your CAD worker folder and setup a worker service on a port that will handle your upgrade server. You can change it all for go live but its just a matter of keeping track of what paths and commands are being executed.
In general terms (and all from memory, apologies for any slight errors):
Thanks for this explanation and all the other responses. It looks to be a lot more involved than I thought. I will investigate and update once I have made some progress. Any more advice or in depth explanations would be gratefully received.
