Is there any windchill option from solidworks to insert components directly from windchill commonspa
SA_12455883
Is there any windchill option from solidworks to insert components directly from windchill commonspace to solidworks assembly.
Current scenario is to add the component to workspace and then use insert component option from solidwrorks to assemble the component
Hi @SA_12455883
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
This will increase your chances to receive meaningful help from other Community members.
Here's what a good question for Windchill looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
Our team also has this question. From within Solidworks is it possible to insert a part into a SW assembly from the Commonspace, without first adding it to a workspace.
Perhaps instead of gaslighting the OP for their question, it would be better to provide an actual answer.
Hello, Currently if we have to add any component from windchill commonspace to any solidworks assembly we need to add first to workspace and the use option insert component.....i want to know if there is on the go option like in creo where we can add component from commonspace directly in solidworks using option insert components from solidworks
I hope its clear now
