Object Reference Attribute displays (Unassignable) instead of an user picker
FS_9776388
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020-CPS11
I was following this guide https://www.ptc.com/en/support/article/CS216763 to create a user picker with a local object reference attribute.
First I added a column via AddColumns utility.
Then I created a new subtype of wt.doc.WTDocument called Fabians_Document.
Inside this subtype I created a local attribute of type Object Reference called Co-Author.
The attribute was set up like this:
Other side attribute: name
Other side class: wt.org.WTUser
Now, when I create a new document of this subtype the attribute Co-Author just says: (Unassignable)
However, I expected to have a user picker there.
Hello Fabian Schmidberger,
I'm Charles from PTC Technical Support in Europe, I will be assisting you with your question opened for Arsandis.
Can you provide corresponding log files via email to cgautier@ptc.com?
Please reproduce the use-case with the error message, then send me the MethodServer log and pinpoint the timestamp and the login used.
Kind Regards,
Charles Gautier.
Hello Charles Gautier,
We also facing similar issue, is there any work around/solution for this issue? If yes, can you please share the related article.
Kind Regards,
Vikram Prabakaran
uharneit
(To:FS_9776388)
I'm facing the same issue, however to get a user picker you can create an IBA / global attribute or local attribute on the document and follow this article
https://www.ptc.com/en/support/article/cs230207
Best Regards,
Ulla Harneit
