Publishing Rules Question
kirkwemple
11-Garnet
We are using some publishing rules to create DXF and STP files for CAD publishing.    When we apply additional rules to only create the DXF/STP files only at certain states (Released and Pre-Production Release), it does not work as expected.   If I manually publish the CAD while at the target state, the DXF/STP files get created.  If I Set State or Promote the CAD to the target states, the viewables are derived from the non released state and the DXF/STP files do not get created.  Is there a method to enforce the publishing rules upon Set State/Promote/ECN to the n target state?
--Kirk Wemple
Newell Brands
--Kirk Wemple
Newell Brands
Setting publish.publishonepmdocumentchange property to true will forced a republish when the state changes.
Setting publish.copyforwardrepresentationsonrevise to false will prevent the viewables from being copied to the newly revised document.
satre-2
(To:kirkwemple)
check the value of evaluate-rules-on-republish property/parameter. Refer below article for more details.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS142964
Hope it helps
Shreyas
TomU
(To:satre-2)
Link is not working...
Marco_Tosin
(To:TomU)
Tom,
the problem is not the document but support site.
It's incredibly slow and, after I refresh a document opened this morning, now I get same error as you.
Document Details
Error:Document 187138 either does not exist or might have been pulled out from the knowledge base
Marco
TomU
(To:Marco_Tosin)
Weird.  It's working now...
