String index out of range: 20
manjunathrv
17-Peridot
When I try to revise a family table CAD parts, I get an error - "String index out of range: 20"
Does anybody have any idea why this error and how to fix this?
The issue was there was a html file attached to the generic that caused this issue.
After removing the attachment we were able to revise.
Can you please provide the server side error message in the MethodServer.log
There should be more info about what went wrong.
Unfortunately I don't have access to the logs
