Upload failure starting "Upload Failure code: J03_WCCLD_CONNECTION_FAILURE locMsg:Connection failed Applies To:....." Submitted on e-support, and result was an SPR to improve error messaging. How do we interpret this in the meantime?
Chrystal,
Can you provide a bit more information as to what actions you were performing when you received this error? Were you creating a WTDocument or an EPMDocument?
Hi, I was uploading a .obj file and it appered a similar error message.
How can I fix this problem?
Michele Barile
Did you ever find a solution for this, I'm receiving a similar message?
I'm having the same issue.
As far as I know this failure appears depending on your connection upload speed.
Did you find any way to solve this?
Thank you
Lluís
