In Windchill 11.0 Datasheet (attached to this discussion), it is clearly mentioned that PSM 4.0 can be used with Windchill 11.0. However, PSM 4.0 is not available in the Downloads section (for Windchill 11.0) and also not listed as part of Windchill Supported Software (for Windchill 11.0).
Here is a question set:
- Can PSM 4.0 really be used with WNC 11.0 (using the Windchill 10.X System Profile and associated Dashboards)?
- Which exact release of PSM (5.0, ..?) is scheduled for Windchill 11.0?
Wait a while! PSM 4 was released before WNC 11.
--But technically PSM 4 can run against WNC 11
For those who are interested, The PSM4.0 F000 will not be listed in the download page of Windchill 11 until the release of the PSM4.0 M010 which will be available around one month or two. It is currently supported to download the PSM4.0 F000 from the WC10.2 section and you can use the set of dashboards of 10.2 during the installation. However to make the PSM connect to Windchill 11.0 the following workaround will be required:
1) Launch the PSM Client
2) Right click on the “PTC Windchill 10.x<Default >
3) Click on the Edit System Profile
4) Click on the method server agent mapping
5) Make the changes in the agent name (instead of v10,make it v11)
For example: Agent Name from:
ptc\.wt\.MethodServer-v10\.[x|(0-9)](.)+
To:
ptc\.wt\.MethodServer-v11\.[x|(0-9)](.)+
5a) Select Apply
6) Make the same changes for the Server Manager and Background Method Server agents.
7) Restart Windchill
Thanks Herve, for the nice information. What may be the reason its not available in the v11 download area ?
but i have not seen any new version of PSM in pipeline to be release.
so i guess we can trust wc11 dataset information and can install psm4 for the windchill 11 to monitor.
