Windchill search
NikeHydraulics-
Windchill search
Does anyone know how to send a search query from a HTML-form and retrieve the search result from windchill server. I want to create a simple search instead of using PDMLink UI.
15 REPLIES 15
Look in the customizers guide for information about using the QuerySpec and QueryResults objects. If you provide more information on the search criteria you are looking for I could help further.
You can use webjects to query information from Windchill. You can launch query by URL at get result as XML. Apply for information to WCAdaptersGuide.pdf
Use the Report Manager to create the search and results page. Then save the search page offline and modify the resulting HTML.
That is a possibility, but that is too much manual labour. I want a search box quering the PDM-link. not manually retrieve the data and handle it.. There will be alot of searching...
The thing is that I have no clue to how to communicate with Windchill. What would be nice is if someone had a tutorial or step by step on how to set up a simple query from windchill to retrieve, lets say, all drawings starting with P/N 40894*. The result should be a table with the drawings listed. I know how to sort the retrieved data in PHP but I dont know how to set up the infoEngine or write the JSP. I also want the P/N to be clickable so taht I can have it in PDF (Which have been published, but the consultant never made it accessable to us).
I found a search function in Ch. 11 of either Customization or adapters guide. But I get Errormessage when I try to run the Demo. Does anyone know why? Message:DCA ERROR: Can not find configuration with id=com.ptc.search:page.search.part for context=(locale=en_US rendererType=java ) I use: http://<host>/Windchill/wtcore/jsp/com/ptc/core/ca/web/gw/gw.jsp?alias=com.ptc.search:page.search.part
Magnus, Did you ever find your answer. I would like to do something similar and would appreciate any help you could give me. Thanks, Tim
Hi, No I havent. Not yet. Though I have come closer in my quest. If you look at http://www.datajett.com/ (found it just, and havent had time to evaluate. But it may be some nice things to look at. The direct link is: http://www.datajett.com/windchill/WC_Dev.htm Also look under : http://www.datajett.com/windchill/ There might be documents that can help us. If you are serious in trying to do this without expensive consultants, I am more than happy to provide what ever information I come accross. my email is: magnus.gabell@nikehydraulics.se
It does'nt get any easier than this.... 1) Select from the "Search" providers pull down in Microsoft Internet exporer (in Version 7, top right corner of app, usually filled in with "Google". Select "Add Search Providers" from the list. 2a) from the "Create your own" part of the returned page, input the following URL, to search by part number. Make sure you fill in the server name where needed (leave in the word 'TEST', thats what Microsoft uses in its program to figure out where to replace what you've typed in the search box): http://<...>/Windchill/wtcore/jsp/com/ptc/windchill/search/CommonSearchPicker.jsp?useAsReportTool=true&objectType=wt.part.WTPart&whereClause=(number=‘TEST') 2b) Give search a name: (ie: Search Windchill By Part Number) 3) Repeat steps 2a and 2b replacing the word 'number' with 'name' in the above URL. This time call the search (Search Windchill by Part Name 5) Repeat steps 2 and 3 again replaceing the word wt.part.WTPart with the word wt.doc.WTDocument and the search name 'part' with 'document. 6) Now you have 4 quick ways to find objects. Note that wildcards work here also (ie: 2345*)
I am under Intraling 9.1, and i try tu use the url:
http://bisapps1/Windchill/wtcore/jsp/com/ptc/windchill/search/CommonSearchPicker.jsp?useAsReportTool=true&objectType=wt.epm.EPMDocument&whereClause=(name='72-5005*')
(I tried with name or number)
But it return me no results.
The standard search page of Intraling found few documents...
any idea?
You can use custom search application by Windchill, http://plmservice.ru/2011/03/windchill-live-search/
source code available.
Thankyou for that Ivan, but, although your application is interesting, it is not what I am looking for.
I have an excel file used by other offices, in wich are some list of part numbers.
I would like to add a column in this file (updated by a vb macro) in wich one will be a hypertext link to open the drawing in internet explorer.
something like:
For i=0 to 1000
cells(i,1).value = "http://myserver/myspecificURLorSpecificWebPage?'" & cells(i,2) & "*.drw'"
next i
My problem is that I am not able to write the specific Url with an article number as argument, or a custom web page, wich will send me back a search report.
i think you can do this only programming using excel API, or write custom application similar to excel on GWT.
Isn-it possible to write a custop webpage in java, wich would accept argument, and wich will do the request to intralink database using apropriate java code?
Hi, i've just found your thread regarding the possibility to search/query in Windchill.
We've defined a really simple to use API with which you can send a URL request to Windchill and it 'answers' back with the appropriate results.
We've built some applications on top of this - you can check two of them here:
http://www.youtube.com/watch?v=MIAZ-kj8s4w
and
http://www.youtube.com/watch?v=I7CS8Ytc17E
The underlying technology is also here the mentioned API. It works really fast and is extremely lightweight. I think you could absolutely use this also from Excel to talk to Windchill. You don't have to do any Java Programming and the impact on the Windchill server is minimal.
Let me know if that sounds interesting!
Just drop us a note at www.nexiles.com
