How can i calculate critical values of Goodness of fit Tests for Weibull Distribution using pearson system
It likes good, but my problem is "when i know the type of distribution of the test statistic say "Kolomogorov Sminrov test statistic " and estimate parameters, critical values can be yielded via the probability density function or the cumulative function of the pearson type?
