AFX Stock table not showing plates/Table Export option from model
YStrypet
7-Bedrock
It seems like the stock table does not consider AFX created plates, only beams. Is this correct behavior?
Another thing I wonder is if there is any possibilities to export the stock length info from the model itself to a text format, so I don't need to go through a drawing to get this information?
Regards Yngve
Hi @YStrypet ,
You can create the feature in all models and then use the available parameters to create a custom BOM if you want to.
See here for usage of the function introduced in Creo 11:
https://www.youtube.com/watch?v=rORtc-91fh0
AFX also offers a outline calculation that can be activated with the following parameter:
This is also already active for most steel_construction_mm elements.
I hope this helps.
Samuel Brantner
B&W Software GmbH
Creo 11 enhances the "Enclosure Volume" feature to allow you to calculate an orientation-optimized, minimal Bounding Box that parametrically updates. You can easily control objects to include and exclude with the collector. Enclosure Volume now gives the ability to update the box volume during ...
Hi @YStrypet
Thank you for your question.
Also, feel free to add any additional information you think might be relevant.
Best regards,
Catalina
PTC Community Moderator
PTC
Hi @YStrypet ,
unfortunately both of your requirements are not possible with AFX at the moment.
We do not know what is your base for your plates. With profiles this is clear. you have a defined section with a variable length.  Plates can be variable in all 3 directions and that is the reason why we do not add them to the mentioned table.
I hope this helps.
Samuel Brantner
B&W Software GmbH
Ok, thanks for the reply.! Could it it be an option to use a bounded box feature? I.e to establish limitation planes on the geometry and measure distance between for display in the table?
Yngve
Hi @YStrypet ,
I hope this helps.
Samuel Brantner
B&W Software GmbH
