Problem while trying to Create BID diagram
glászló
Hi everyone,
I was trying to create BID diagrams, and I have a big problem. In the bid I want to connect multiple connectors with one fiber, but I simply can't find a way how. I've attached a picture, what indicates that in the help it says fibers L4 and L5 connects x-y-z connectors in a simple network...ect. Well I've tried to connect two connectors to a third one, but I can't "expand" (??) my existing fiber. On the second picture you can see, the fiber that connects 03 with JP1 is named Bharn_1, I'd like to connect J1 to this harness with the same fiber (Bharn_1), but if I route a fiber again I can't even attach it to Bharn_1 (I've just terminated the end of it..... ). How should I do this? (SG-21-00-12 is the harness name, I'll have some more questions about the bid-wid connections soon)
Laszlo
Laszlo
Please take a look at the attached video.  I used the sample design that is available on the getting started tab to create the video.
Let me know if the video does not help
thanks, Jim
Laszlo
thanks, Jim
Jim,
Thanks for the answer, it's done!
Laszlo
