Sheet metal flatten view of revolve part
rkadam
Dear friends
Here i am attaching my part file of revolved sheet metal part ,please help me to develop (flatten view)
Message was edited by: ROHIT KADAM
habdul
(To:rkadam)
Because there's a surface with bi-directional  curvature, you'd have to define a deformation area. This will be based on prior knowledge of how this geometry/material behaves in the deformation process when you bend up the flat. Unbending is standard for surfaces with curvature in one direction only, like cylindrical surfaces.
Also make sure you have valid "fixed geometry" to use as unbending reference. Version 1 doesn't have that.
