Hi All,
I tried to run the asynchronous Jlink Full Example under this path - Creo 7.0.2.0\Common Files\otk_java_free\otk_java_appls\jlinkasyncexamples
But the performance has been inconsistent, sometimes the creo parametric app opens, sometimes it doesn't.
Other times the session starts but the model is not loaded. Only few times it has successfully started a creo session and loaded the model.
Is there something that I am missing? Can the application be optimized in some way?
Apoorva
Hi the JOTK async examples behaves randomly in your environment. That's unexpected.
An article offers a tutorial to create and run it.
Can you confirm you followed all the steps?
https://www.ptc.com/en/support/article/cs360564
