2 blocks & 3 mass
ValeryOchkov
24-Ruby IV
2 blocks & 3 mass
Help please to solve this ODEs task. The first try (Prime 3.1) in attach
F.M. написал(а):
Beautiful, .... but the woman ... the one of the photo, is even more ...
Woman and Flowers!
You can change L, masses, start point and get new woman, flowers etc!
108 REPLIES 108
vlehner
(To:ValeryOchkov)
Wouldn't it be better, to study the geometrical relationships before starting calculation?
Volker
-MFra-
21-Topaz II
(To:vlehner)
Hi Valery,
Can we describe the problem the following way?
The material system consists of five bodies: the masses M0, M1, M2 and the fixed disks' masses μ1 and μ2, of equal rays r. The wire is inextensible and, by chance, it does not creeping.
Determine the system motion and the tension in the wire.
Can we choose the location of the reference system's origin, at our discretion? For example so:
or is it fixed at L/2?
Thank you
F. M.
vlehner
(To:-MFra-)
Hi F.M.
I guess it's fixed at L/2 and y0.
After releasing the weight m0 at this position, the system finds its equilibrium.
Putting the center of the first disk to the origin of the coordinate-system would be advantageous for solving with Lagrangesche Formalism.
The equations should be more simple than.
Viel Erfolg!
Volker
Volker
-MFra-
21-Topaz II
(To:vlehner)
Salve V. L., in fact I will use the Lagrange equations.
We usually choose the origin of the axes in such a way as to make the equations as simple as possible. Valery put it in (L / 2, 0) not in (L / 2, y0). This last is your choice.
Viel Spaß
F. M.
vlehner
(To:-MFra-)
You're right.
I think too it's the best way to choose the origin like you suggested.
Now I try the formalism.
Cappucino now
Espresso Lagrangesche
tanto divertimento
Volker
Volker
vlehner
(To:-MFra-)
Tried to use the Lagrangesche Method.
creating the differential EQN for the x-direction is ready, but it's very large. (it took a time of 30 minutes!)
Now there is to do the same for the y-direction.
see attachment please.
I'm not sure if both equations will work in a solve block.
What generalized koordinates can we choose for the Lagrangesche, that the equations become more comfortable and smaller?
Maybe with angles?
I really don't know and it seems to me that a solution here with Newton is necessary.
Viel Erfolg!
Volker
Volker
Thanks, Volker!
But es ist zu komplizirt for me.
I think we must begin with the static task with r=0 (warum nicht?).
It will be a key to solve the dynamic task.
You will laugh, but it seems to me that I solved the problem. We have an attractor at air resistance and one perpetuum mobile without it.
In oil not in air
Strictly speaking you haven't implemented the damping correctly here!  If the damping force is proportional to velocity squared (or velocity*|velocity|) then you need to calculate the damping force using the resultant velocity and then resolve that along the x and y axes.  This will not be the same as calculating x and y damping forces using the separate x and y components of velocity, in general.
Alan
Alan
Thanks, Allan!
I know it but we use one simple model!
Help please here Sheets Mathcad 15 and Prime - one bug
vlehner
(To:AlanStevens)
Alan,
if I understood you right, you meant this?
Volker
Volker, Yes.  We should have Fwx = Fw*cos(theta) and Fwy = Fw*sin(theta)    where Fw is as you've defined it and theta = tan^-1(vy/vx).
However, this would only be of importance in a real problem - it doesn't matter too much in a toy problem.  It's just the pedant in me pointing it out!!
Alan
vlehner
(To:AlanStevens)
Thank you!
Volker
Alan
One compromise:
Ok. I might as well show my solution using damping in the form I mentioned previously.  Note that my worksheet is M15, and first does a static equilibrium calculation, then does the dynamics (only the dynamics part pictured below).
Alan
Thanks, Alan!
But a solution without an animation is not solution.
A solution with one animation is not solution too.
Tree animations are good!
Video Link : 7859
Video Link : 7860
Video Link : 7861
Valery Ochkov wrote:
Thanks, Alan!
Ok. Here is a (not very exciting!) animation:
Video Link : 7871
Alan
Sorry, Alan!
I do not see an animation.
We must convert avi to mov and than input it here.
Attach please the avi file - I will convert it and put here!
Ok Valery, thanks.  avi file attached.
Alan
Alan
Video Link : 7872
Sorry. The solution with animation but without trajectory is not full solution
Animating a simpler task in Smath Studio
http://en.smath.info/forum/yaf_postst973_Animation-double-pendulum-and-a-pendulum-on-a-spring.aspx
Fluctuations of three loads .The system consists of two extreme loads mass m1 and medium load mass m2 (2m1> m2).If the average load deviate from the equilibrium position, the system begins to oscillate.
Sorry. The solution with animation but without not simple, interest, fine trajectory is not full solution!
vlehner
(To:ValeryOchkov)
Valery Ochkov schrieb:
One compromise:
Maybe we don't need a compromise:
Volker
Zu compliziert for me
Sergey Dovlatov about one compromise:
"Дело происходило в газете "Новый американец". Рубин и Меттер страшно враждовали. Рубин обвинял Меттера в профнепригодности. (Не без основания). Я пытался быть миротворцем. Я внушал Рубину: — Женя! Необходим компромисс. То есть система взаимных уступок ради общего дела. Рубин отвечал: — Я знаю, что такое компромисс. Мой компромисс таков. Меттер приползает на коленях из Джерси-Сити. Моет в редакции полы. Выносит мусор. Бегает за кофе. Тогда я его, может быть, и прощу."
It happened in the newspaper "New American". Rubin and Metter were terribly hostile. Rubin accused Metter of being unfit for work. (Not without reason). I tried to be a peacemaker. I suggested to Rubin: "Eugene!" A compromise is needed. That is, a system of mutual concessions for the sake of the common cause. Rubin answered: - I know what a compromise is. My compromise is this. Metter crawls on his lap from Jersey City. Wash floors in the office. He takes out the garbage. Running for coffee. Then I, perhaps, will forgive him.
vlehner
(To:ValeryOchkov)
Did you try it?
You cant say its zu kompliziert for me without trying it!
Volker
Volker Lehner написал(а):
Did you try it?
You are right.
vlehner
(To:ValeryOchkov)
Thanks, Volker!
And meanwhile, i think so too.
I try to solve it now with Newton by myself.
Let's see what F.M. makes with the Lagrangesche.
Volker
I do not show the picture with solution!
You can see the attach or not see - try to create yourself and compare than!
