CSPLINE and iteration
JBlackhole
16-Pearl
to all
I am looking at some programme which will involve curve fitting (possibly). I had a look at the doc and it seems quite straigforward but I am not getting what I expect when attempting a plot of the cspline. The overall problem is explained in the attached mcad (can't copy and-paste)
JXB
13 REPLIES 13
The attached file should help with cspline and linterp
thanks Werner. Make sense now!
How does one interpolate between 2 sets of known data then? For example (see also attached) if one has data for a ratio b/d=0.1 and b/d=0.2 but one wants a Y value (K on the mcad sheet) for say b/d=0.164? Should one construct a "dummy" curve (spline) between thw 2 sets of data
basically - yes. You are asking for a 2-dimensional interplolation. Guess the attached sheet should help.
file attached
See attached
Werner
What does the function f(p,bd) do? I think I get the other 3
JXB
it's some kind of example!
Managed to have the "bounding" curves as a function of the ratio b/d. Your proposed interpolation function seems to return a "correct" estimated K value for a given ratio b/d and py/M value. See attached
Need to see now if I can incorporate the csinterp_2D functions in the iterative function
JXB
Thats the 2D interpolation, You have a rectangualar data table wher you can look up a K-value for given py/M and b/d. The function f does exactly this but it interpolates inbetween the given values. Maybe I should have called it K() instead of f(). First parameter b is the ratio b/d, second parameter p is the ratio py/M. f() basically is a 2D-surface (see picture below) and the curves you are drawing are slices of that surface for constant values of b/d. So I can use f() to create those functions bdxxx(p) which show the K-values for varying py/M and constant b/d.
Werner
Thanks for the clarification. I think I am getting there
I have now the program to calculate the value Mmax by 1st interpolating for K. It seems that the loop does not quite converge to the expected answer.
I expect K to be close to 0.44 (and therefore indirectly Mmax close to 12870) but the program seems to converge to K=0.451. There must be something in the interpolation maybe
JXB
Haven't looked at the file and not at what the goal of your iteration would be, but splined tend to be "wavy" and sometimes its better to use simple linear interpolation.
test with the linterp in function GetMmax give indeed slight different results
with linterp_2D nb of iteration n = 18, K final =0.451
with csinterp_2D nb of interatin n= 18, K final = 0.456
a plot of the K value for each iteration doe shows some "wavyness"
The values you calculated are correct and they are more precise as those given in the reference (they are rounded to 2 decimals after every step). Nevertheless there is an error in your calculation which leads to this "wavyness" (which is not due to the splines). The error is the in the calculation of PyM you should use Mmax[i and NOT Mmax[i-1. Chnage that and you get a continous approximation.
Find attached a slighty modified routine.
Thanks a lot for that. Much appreciated. I changed the espilon value to K[i- K[i-1. Convergence is quicker as K value is smaller
