The |..| operator was set to 'matrix determinant' not 'absolute value' (look up in help, usually right-click and select, but in this case I had to cut the long expression in the second equation, substitute a dummy variable, set | | to abs and then paste the original value back in.
Stuart
Stuart
thank you for fast answer.
Is there any other way to avoid divide by zero in denominator exclude subtraction from sine infinity small value?
No worries.
Yes. Examination of the equation reveals that there is a simplification at Fd = 0. The easy way to deal with it is to move the expression into a function and handle Fd=0 as a special case.
Stuart
