i am trying to plot this surface, but it is not showing. not sure what i am doing wrong. Thank you!
See the attached for one possibility. You can play with the appearance to your heart's content.
Alan
Alan
Thank you Alan!
what was wrong with the way i was doing it? i thought mathcad will draw the surface without "Ceate Mesh" command.
In Mathcad 15 when you are plotting a function, you need write the function name f in the placeholder. and not f(x,y) as you had done.
In Prime you can do write it both ways, function name only or function name with arguments.
Thank you Thomas!
Hello Thomas,
The shape that i have pasted in my sheet for the end result does not match what you are showing. what needs to be done? Thank you!
oh, I may have rotated the plot slightly and zoomed in on it ... nothing else.
Thomas,
The plot you have does not match what Alan did. Is there away by using your method to plot the function to look like Alan's?
Compare the following:
I prefer the CreateMesh version!
Alan.
