This value must be a scalar error
BillDumke
I need to have a function that works with a vector that could be any length. How do I get rid of the range variable requirement? See attached Mathcad 11 doc.
Bill
Try the attached Bill.
Mike
12 REPLIES 12
MikeArmstrong
(To:BillDumke)
Like the attached?
I have used the pre-defined vec function in the collapsed area.
Mike
I see the vec() function in the utiltities list, but I don't see where you used it.
MikeArmstrong
(To:BillDumke)
I used it to define I.
Mike
I see that. But nothing else works on the sheet after that. Get "Illegal Function Value" error for Vf(I).
MikeArmstrong
(To:BillDumke)
Sorry Bill,
I didn't even look down the page after the vectors. I am mad busy sorry.
See attached.
Mike
I see the Vf program, but the numbers are to the 22nd power and 0 does not exist for I < 0. I can wait till tomorrow if it will help you. Thanks for the effort.
Bill
MikeArmstrong
(To:BillDumke)
Are your number correct in the first worksheet you posted?
Mike
Yes, it plotted correctly as well using range variables.
I think the problem is the program does niot replace the complex numbers below zero with zeros.
Mike
Works Great! Thank you very much for taking the time.
MikeArmstrong
(To:BillDumke)
No problem. Sorry for the lazy efforts.
Mike
