Learning Connector not functioning with IE 11
ploney
8-Gravel
Has anyone had any luck getting the learning connector to work with Creo 2 M100 and Internet Explorer 11
I am getting a script error with a Yes No to continue.
Once I hit Yes to continue, I only get a blank window and no content.
There is a Support item available. https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS181958
The changes prescribed within that document don't apply to my Companies flavor of IE11
I am awaiting response from my companies corporate IT at the moment.
Any help or suggestions beyond CS181958 ??
Clint Walton wrote:
Peter,
There might be some useful info in this thread if you haven't already seen it.
Re: Learning Connector issues (?)
Thanks Clint.
I actually posted a solution in the other thread for all to reference of what worked for us at my company.
We have had trouble running on IE11.
We uninstall and hide the IE11 update.
We found windchill 10.0 only operates correctly on IE10 or lower.
I don't know about later versions of WC
Peter,
Clint Walton wrote:
Peter,
Thanks Clint.
