Hello.
I'm using CREO Parametric 3.0 M060 with Windchill PDMLink 10.1 M040. In the Config.pro I set the option "rename_drawings_with_object" to "both".
When I create a new part and save it to the workspace, an drawing with the same file name is created.
But is it possible that the created drawing also gets the same Common Name as the Part? Of course not by a manual rename...
Thanks in advance!
Mark
