How to modify a Structure tree presented in Create Trace wizard?
AN_10548594
Helo team,
Found these example inside Solution\Properties and see that wizard uses Query "FinderProjectsAndTestObjectives" and interesting option called "additionalFilter"....
Query returns a list of ReqDocs\TestDocs of selected project and tree representation of selected docs in at the right pane.
"title=Select tests to run","query=FinderProjectsAndTestObjectives","additionalFilter=((subquery[FinderProjects]) or (field[ID] = {{ID}}))","focusIssueID={{ID}}","fields=Structure","nodeDisplayFields={ID} {Category}- {Text}{Summary}","showFieldNodes=false"
What's needed is a way to get rid of some requirements (Rev 0.0, or State "Unfinished") in that tree by using filters or maybe other options.
Hi @AN_10548594
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
