How to get "Global Enumeration Used" in the "Constraints" tab of a Classification Attribute
Manoj_Dokku4
I have a classification attribute named Colour with internal name COLOR,
in the Constraints tab, I have assigned global enumeration which is having internal name Colour(COLOR_ABC).
Is there any api available such that when I give an input of Classification Attribute internal name (COLOR), my output should fetch the global enumeration used COLOR_ABC.
@HelesicPetr
If I do understand you correctly, you want the display value of the selected enumeration. This is found e.g. in the support case:
https://www.ptc.com/en/support/article/CS204076
Important is, that you always need to load the classification link attribute together with the needed attribute.
@BjoernRueegg , thanks for the reply.
This will work If you have a persistable object, but in my scenario, I know only the Internal Name of the classification attribute used, need to get the Internal Name of External Global enumeration used in the Constraint.
MTH
(To:Manoj_Dokku4)
You need to check for the constraints of the attributes then filter on the constraint of type global enumeration
