55
Views
| Thanks for looking. 🙂 I have a laptop running a fresh install of
Arbortext 8.2.2.1. As in, freshly ...
55
Views
by
plutsky
on
May 01, 2024
02:27 PM
77
Views
| The Arbortext Web Editor and Reviewer products improve the overall
process of creating service and p...
77
Views
by
JE_11013556
on
Apr 19, 2024
01:32 AM
Latest post on
May 01, 2024
10:23 AM
by
Alexia
261
Views
| Hello, I would like to ask your opinion or help on the following faults
encountered in Arbor text 8....
261
Views
Using 40051D_7_0. I'm trying to set up a standard Index, but can't seem
to get the topic location pa...
54
Views
301
Views
| Hello, we've setup Windchill (12.0.2.x) with SSO , and Microsoft Entra
ID as the CAS and IdP, which ...
301
Views
by
WM_11018447
on
Apr 09, 2024
08:36 AM
Latest post on
Apr 15, 2024
07:06 PM
by
GarethOakes
365
Views
| We are currently using Arbortext 8.2 and would like to know how we can
get the absolute offset (star...
365
Views
by
DH_8838333
on
Apr 12, 2024
03:24 PM
Latest post on
Apr 12, 2024
03:28 PM
by
DH_8838333
1 Reply
226
Views
| I have installed and reinstalled Arbortext 8.2.2.0 several times now
chosing the Print Composer opti...
1 Reply
226
Views
by
ChrisWestern
on
Mar 14, 2024
05:49 PM
Latest post on
Apr 12, 2024
06:53 AM
by
ChrisWestern
263
Views
| Arbortext ALD World Users event 2024 We are pleased to announce to the
community our next users meet...
263
Views
315
Views
| I need to call a method right after a file is opened in the editor. Is
there such an event somewhere...
315
Views
by
SL_11019533
on
Apr 10, 2024
08:55 AM
Latest post on
Apr 10, 2024
06:37 PM
by
GarethOakes
307
Views
| We're doing an upgrade from Arbortext 8.1 to 8.2 and use a floating
license on the peserver. From th...
307
Views
by
JE_11013556
on
Apr 04, 2024
08:01 AM
Latest post on
Apr 04, 2024
11:07 AM
by
Alexia
628
Views
| Hello everybody, can somebody help me? I'm using Arbortext 8.2 but can't
preview or export PDFs beca...
628
Views
by
DL_10914713
on
Mar 26, 2024
09:53 AM
165
Views
| Hi Folks, I am working on some XML that uses XSL-FO engine to create a
PDF. In particular, this styl...
165
Views
by
plutsky
on
Mar 25, 2024
10:57 AM
170
Views
| A new version of Arbortext Editor/Styler/Publishing Engine is available
on the software downloads si...
170
Views
by
jhubackova
on
Feb 02, 2024
08:09 AM
Latest post on
Mar 22, 2024
05:01 AM
by
jhubackova
459
Views
| Hello, I want to use PDF Form Field functionality (in ATX 8.2.2) on the
Title Page of the book(via p...
459
Views
407
Views
| Version: 8.2.1.0 I also have installed version 8.1.2.1 in another
directory. Opening PTC Arbortext w...
407
Views
571
Views
| Hi, We're trying to eliminate an element used throughout our document in
Arbortext, but retain the t...
571
Views
459
Views
| Hi together, from the Arbortext Editor i can only find a deployment kit
version of 8.1. Is it planne...
459
Views
401
Views
| I need to add a callback on when the DELETE key is pressed. I don't need
to change the behavior of t...
401
Views
by
PS_10983287
on
Mar 07, 2024
04:49 AM
Latest post on
Mar 15, 2024
08:03 AM
by
bfriesen
801
Views
| Hi,On a few Windows 10 machines in our company PTC Arbortex IsoDraw 7.3
M090 Build 7 crashes on appl...
801
Views
307
Views
| Hello, Do you know how I can find the bottom right corner position of
all the elements of a CGM illu...
307
Views
349
Views
| I'm adding a callback on the Save option in the Arbortext Editor menu.
The callback works perfectly ...
349
Views
1 Reply
256
Views
| Hello ! I'm starting with Isodraw Macro, do you know the code to find
the active opened file name ? ...
1 Reply
256
Views
by
YS_6748782
on
Feb 27, 2024
01:39 AM
Latest post on
Feb 27, 2024
08:34 AM
by
bfriesen
1 Reply
178
Views
| Currently using ISODraw CADprocess 7.4.0.0, There is no options to UNDO
or REDO. Can you please help...
1 Reply
178
Views
456
Views
| I read the APTCUSTOM value using local tmpPath =
$main::ENV['APTCUSTOM']; If I look at the string sh...
456
Views
by
hbestler
on
Feb 15, 2024
05:07 AM
Latest post on
Feb 20, 2024
11:39 PM
by
GarethOakes
399
Views
| Hi together, we would like send some elements as string to an external
.exe Tool, and want to get th...
399
Views
394
Views
| Currently we have an acl script that adds the username to any comments
that are inserted. There has ...
394
Views
by
dgopois
on
Sep 25, 2019
08:18 AM
Latest post on
Feb 19, 2024
05:44 AM
by
DL_10914713
1315
Views
| Hello, With Arbortext Editor, is it possible to combine XML Documents
and Fragments Using XInclude ?...
1315
Views
by
MM_10905425
on
Feb 14, 2024
09:30 AM
166
Views
| Tue, Feb 27, 10:00 AM EST In this session you will learn what just
released in Creo Illustrate 10.1 ...
166
Views
by
bfriesen
on
Feb 09, 2024
01:25 PM
Latest post on
Feb 12, 2024
06:25 AM
by
GarethOakes
1 Reply
176
Views
| We are having issues with poor hyphenation placement for translated
languages. I have found this htt...
1 Reply
176
Views
by
PP_10949316
on
Feb 08, 2024
12:31 PM
Latest post on
Feb 12, 2024
04:21 AM
by
GarethOakes
1 Reply
165
Views
| I have a lot of XML files that are revised by random people. These XML
files can have the element PA...
1 Reply
165
Views
Subject | Author |
